  #1
Old 08-23-2017, 11:10 PM
Micheal Tomac's Avatar
Micheal Tomac Micheal Tomac is offline
been pulling forever
Default 2017 Allison EPC solenoid plug
Does the 2017 Allison still need this to keep line pressure up at all times?
__________________
2017 Chevy 3500 srw 4x4 Z71 CCSB L5P
2002 Chevy 2500HD 4x4 CCSB LB7
2.5 Turbo, ATS dual CP3's, Crower rods, SoCal stage2 heads, SoCal Cam, SoCal Pushrods, ARP head & main studs, Exergy Injectors, Kennedy lift pumps, FASS 150, EFI Live, PPE Manifolds & up-pipes, Banks Intercooler, ATS Extreme trans, ATS Copilot, ATS 5 Star, ATS flywheel, 5" DHD intake, 5" DHD exhaust, 4" ATS downpipe, Elocker, DHD Spool, SCS Axles, pulling hitch, tierod sleeves, centerlink brace, traction bars, 315x70x17 BFG AT's & some pulling mods = 2014, 2015, 2016 MTTP 2.5 Prostreet Diesel Points Champion, 2009 & 2011 MTTP Hot Diesel Points Champion, 2009 NADM 2.8 Points Champion, 2006 & 2007 DIESEL POWER CHALLENGE WINNER, 2007 best 1/4 mile - 11.24@120 mph
  #2
Old 08-27-2017, 12:06 PM
RVN4ME's Avatar
RVN4ME RVN4ME is offline
FNG
Default
Quote:
If I could afford one I would look.
PCA/EPC
Positive Terminal (Wire Color) 3 (Green)
Negative Terminal (Wire Color) 1 (Gray)
Harness Connector Color Green
__________________
07 Chevy Classic 2500HD 4x4 2LT LBZ CC/SB White
Nasta nerf bars, Line-x, Bilstein shocks, Firestone air bags, Fold-a cover, Good/Year Wrangler S/A 265/75/16 E 2005 SunnyBrook 30RKFS 5er 11,300 lbs. dry
  #3
Old 08-27-2017, 07:24 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
As far as my info goes; yes. Pressures are the same as the '16.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #4
Old 06-18-2018, 01:07 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Has anyone tried one of these?
https://www.dirtydieselcustom.ca/col...c-fooler-75450
  #5
Old 06-18-2018, 01:24 PM
Mike L.'s Avatar
Default
Quote:
Originally Posted by LBZ View Post
Solenoid is cheaper and you don't have to remove valvebody. Solenoid is plug and play.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #6
Old 06-18-2018, 01:32 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
Deviant makes that plug. Itís cheaper through them. I didnít think the valve body had to come out for those plugs, mike? Iíve always just done the solenoid mod like mike said
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #7
Old 06-18-2018, 03:03 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Quote:
That price is in Canada pesos. So like $60 US. What's the solenoid worth? About the same from some of y'alls allison dealers down there iirc. I'll check online again.
  #8
Old 06-18-2018, 03:20 PM
Chevy1925's Avatar
Default
ah i forget you're up there Dale.
__________________
James
  #9
LBZ's Avatar
LBZ LBZ is offline
Default
$70 for the solenoid from the allison dealer in calgary. So I'll probably go that route. P/N is 29541895.
I've got 45k miles on the truck now so I know the oil is still good but i've got an 8 y/o sealed pail of Transynd that I need to pour into something. I don't think oil goes bad does it? Other than water contamination.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
