  #16
Old 06-12-2018, 06:05 AM
duramax on fire duramax on fire is offline
Thanks man. May end up doing that. Going to try a few more things before we cal uncle lol. Replacing injectors is easy to me compared to steering and suspension. Your in Tyler correct?
  #17
Old 06-12-2018, 06:06 AM
Originally Posted by Chevy1925 View Post
tie rods are mounted UNDER the knuckle correct?
I will check that today for sure. Thanks chevy
  #18
Old 06-12-2018, 07:13 AM
JoshH's Avatar
JoshH JoshH is offline
I'm in Van which is between Tyler and Canton.
06 Silverado 4x4 CC/SB
  #19
Old 06-18-2018, 07:38 PM
OK!!! finally had time to really look at this thing instead of quickly checking things. Found the issue. Someone put the wrong idler arm on. It put the center link at an angle and tie rod was 3/4" lower on the pass side than driver. Changing the geometry every time it hit a bump. I feel stupid that we didn't catch it sooner. But then again alignment shop didn't catch it either lol.
But all is well now. Drives like it should. no more problems until the next time lol. thanks for all the help
  #20
Old 06-19-2018, 04:06 AM
trashygasman's Avatar
trashygasman trashygasman is offline
Slowly but Surely
Good to hear you found it.
Kyle
2006 White Silverado LBZ, CC/SB 4x4
EFILive by JoshH, MBRP, S&B, Transgo Jr., AirDog 150, ProFab EGR Delete & Downpipe
  #21
Old 06-19-2018, 07:21 AM
Chevy1925's Avatar
good to hear. this is more common than you think. Ive had guys install the tie rods up-side down too which will cause the same issue as well. induces a shitload of bump steer.
James
best time to date: 12.39
Tailgate Crew Member #4
  #22
Old 06-19-2018, 08:05 AM
I did check that first thing after you mentioned it. They are on bottom. We figured the front end was original being 100k on the clock. But o well. Going to trace part number and see what this one was suppose to go to. Just currious.
  #23
Old 06-19-2018, 10:33 AM
JoshH's Avatar
Probably a 1/2 ton part.
