  #136
Old 12-27-2015, 07:42 PM
N2BRK N2BRK is offline
Default
I was a little surprised, and I'm not sure how to assign "blame" if that even fits. Rather than blame, since I'm over stock turbo power, I'm trying to think about it as a weakest-link thing.
Yes, the UI "failed", BUT that means that the Kryptonite centerlink and tie rods "failed". If the Kryptonite was up to the task, then the UI would never be asked to bear the load and fail. I think that this proves that even with the super-sized Kryptonite hardware, it is still NOT as strong a straight centerlink. But, I used to run a big straight centerlink, and I wouldn't go back.
I had a lot of initial reactions to this discovery, including thinking that a stock centerlink with sleeves and a DHD bracket wold be all that you ever need. But, then I thought about the strength needed for turning under big loads - like last summer backing up a 7 ton load in the back yard at full-lock in 4wd... the Kryptonite parts were reassuring. Plus, even though it was over powered, the Kryptonite does give the idler (and DHD for that matter) more leverage than the stock centerlink too.
Dunno.
__________________
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #137
Old 12-27-2015, 07:43 PM
Default
just the stud. The bearings still spin pretty well and the casting looks fine. I have a video of it, but I can't get it to upload here.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #138
Old 12-27-2015, 07:45 PM
Default
the funniest part is that the truck drove in 2wd like nothing was wrong at all!
__________________
08 LMM Crew 4x4
Exergy 12mm
  #139
Old 01-03-2016, 07:36 PM
The Kansan's Avatar
The Kansan The Kansan is offline
Default
Im glad to see that DHD brace will fit with Kryptonite Center link as well, been wanting to switch to that from the cognito supports . Someone mentioned the straight center links dont turn as well but i havent noticed much different turning radius with mine. If i were to do it all over again id probably just do stock centerlink, sleeves or a good beefy tie rod and a DHD brace, seems to work well for a lil less money.
__________________
-2003 CCSB Silverado-
-Billet S366
-Spearco Intercooler
-Suncoast Trans-1055 Converter
-ARP Head Studs
-40 Over Injectors
-PPE Manifolds & Up Pipes
-5 Inch Exhaust
-FPE Lock up box
-Kryptonite Center link
and Tie Rods
-Remote Modded CP3
-HSP Pulley
-HSP Intake
-Cognito Traction Bars
-Cognito PISK
-Relocated FICM
-Airdog 200
-Merchant Motor Mounts
-EFi Live by me
  #140
Old 01-16-2016, 05:34 PM
Default
Found a little rubbing from the lca bolt to the DHD brace. I cut back the bolts to clear
__________________
08 LMM Crew 4x4
Exergy 12mm
  #141
Old 01-16-2016, 05:35 PM
Default
Other side
__________________
08 LMM Crew 4x4
Exergy 12mm
  #142
Old 01-16-2016, 06:46 PM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
Quote:
Yup, cut the extra threads off and all good.
__________________
Sean
02 CCSB
Moonshine tunes, MikeL trans, Exergy Sportsman, 4/6 drop, LML 20's/420's
  #143
Old 02-22-2016, 05:41 PM
booxr800's Avatar
booxr800 booxr800 is offline
Boo
Default
I just put my brace on today. Turning right seems all fine but turning left I lost a lot. Is it the bolt on the LCA that I may be hitting? I will have to check in the morning.
__________________
2008 CC/SB Z71
Tuned by Mark @ Danville Performance
DHD Trans - ML G Converter - Homemade Trac Bars
ProFab Y Bridge, 3'' Cold side, Tow Flow Up Pipes
Banks CAI - ADII 165 4G - 3/5 drop
285/55R20 Cooper AT3 on KMC Monsters
  #144
Old 02-22-2016, 06:10 PM
Default
possible Give it a look!
__________________
08 LMM Crew 4x4
Exergy 12mm
  #145
Old 02-22-2016, 06:22 PM
moparkxracer's Avatar
moparkxracer moparkxracer is offline
Default
That's what mine did, had to trim the bolts.
Quote:
__________________
Thank you to:
Engine build: Burkett racing
Transmission: be in Evans hands soon
Turbo spec: Shane (S Phinney on here)
Turbo kit built: myself and Landon at Shade tree triples
Tuning: Mark at Danville performance
Fueling: Exergy
And everyone else who made this possible, Thank you!!
  #146
Old 02-22-2016, 06:57 PM
Rancelot211's Avatar
Rancelot211 Rancelot211 is offline
Boyd
Default
Same here on both sides
__________________
2007.5 lmm Ccsb: 628hp 1237tq- sold
  #147
Old 01-14-2017, 08:07 AM
ctodd36 ctodd36 is online now
Gearhead
Default
Excited to get tony's brace on my puller to see how it fairs over the Cognito stuff! After reading all of this it looks like this is the way to go
  #148
Old 03-20-2017, 10:09 AM
Venom Racing's Avatar
Venom Racing Venom Racing is offline
Family Race Team
Default
We are also excited to Get all of Tony's chassis stuff installed! We are building this chassis as if it was a Diesel puller. It will only have a stock gas engine for one season then we will be adding some big power. I will post up chassis part install as we go! DHD for the win!!! We only run the best parts and Tony offers what we want! Quality and Best service around.http://www.venomtruckpulling.com
[IMG][/IMG]
This truck is our first Chevy build on the team and it will be driven by my wife. She is out to hurt some of the guys feelings Follow us at instagram Venom_truck_pulling and Havokracerchic
We also have a Facebook page under Venom Truck Pulling.
2004 Chevy 2500 HD reg cab LB. Called "HAVOK"
  #149
Old 03-31-2017, 07:21 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is online now
Default
What tool is everyone using to trim the bolts?
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
  #150
Old 03-31-2017, 07:28 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Default
4 1/2" peanut grinder will work just fine joe
__________________
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Tuned by Aaron Wiebe
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to: Scott@ SDP, Aaron Wiebe @ All In Truck Performance, Lyle & Clay @ Bama Offroad, and Justin Goode @ MBS Diesel
Best time to date: 12.80 @ 110.78
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
