Old 03-20-2017, 06:04 AM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default Front Diff Lift mod
Has anyone heard of modding a front diff by cutting off the top mount for a lift kit? I got a diff this weekend to replace the one in my truck, and I didn't notice it until we were trying to shove it up into the truck, but there is no top mount. On looking, someone cut and ground the mount off, and from the looks of it, it doesn't appear to be fresh, and it wasn't obvious. We were thinking maybe it was because it came out of a gasser truck, until we noticed that it appeared to have been cut/ground.
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
Old 03-20-2017, 06:07 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
That's what the majority of the kits have you do kinda sucks. Someone offers a bolt on bracket to fix them I just can't remember who.
04 LB7 ECSB Built motor, Wagler narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
Old 03-20-2017, 06:10 AM
Michigan_LMM's Avatar
Michigan_LMM Michigan_LMM is offline
Gearhead
I believe you have to cut it off when installing all lift kits. Just cut mine off for a zone kit. Below is a bolt on mount from DMAX store if you are still trying to put it in a stock truck
http://dmaxstore.com/products/?route...product_id=647
2007.5 CCSB
S468
HSP Trans
LB7 pistons
PPE manifolds/up pipes
6" Zone lift set around 3"
Old 03-20-2017, 06:12 AM
TLyons90's Avatar
TLyons90 TLyons90 is offline
Pretty sure its Cognito who sells the bracket.
Troy
Current - 15.5 Denali | Exhaust | Tuned | Lowered | Sleeved | Wheels/Tires
Toys - Honda Grom | To Much To List
Sold - 11 CCLB, 08 ECSB, 07 RCLB, 04.5 CCLB, 04 ECSB
Old 03-20-2017, 06:18 AM
onebaddmaxxx onebaddmaxxx is offline
cognito sells a bracket to bolt a mount back on!
2005 lly
Lots of thanks to Diesels Unlimited, Evan@limitless & Mark@danville
Old 03-20-2017, 06:46 AM
Cougar281's Avatar
Thanks guys. Never heard of that until I saw a blurb in a car-part listing about cut off for lift kit. That is beyond stupid, IMO..... The yard is going to get me another diff that's intact.
Best 1/4 times:
446.4RWHP/820.2RWTq
Old 03-20-2017, 07:22 AM
Chevy1925's Avatar
its extremely common and an easy fix with the bracket. obviously if you got it from a yard id get another.
be very sure its not 4.10 gears either and i have been told that the casting for a gas front diff is not as strong as a diesel. i have not verified this myself yet though
James
best time to date: 12.39
Tailgate Crew Member #4
Old 03-20-2017, 08:46 AM
Cougar281's Avatar
I can't imagine that being the case, assuming both are 9.25". I can see that as a logistical nightmare as all you'd need is one small messup at the factory and you have a run of diesel trucks with diffs that look the same but aren't as strong. Minus the missing mount, the one out of the gasser appears to be identical to the one out of my truck.
Best 1/4 times:
446.4RWHP/820.2RWTq
  #9
Old 03-20-2017, 09:19 AM
Chevy1925's Avatar
i wouldnt put it past AAM to do it. remember, our 11.5 is the same exact ring and pinion as the dodge yet the dodge axle has bigger tubes, different axle flange bolts, a limited slip we never got, and a few other differences. There are also alot more gasser 9.25 diffs over the diesel and they are not assembled on the same assembly line. the possibility is there, id just have to see the inside and outside of both cases to agree. it may not be more than just one more added casting brace or a thicker rib where the cases bolt together. little things
James
