  #1
Old 10-18-2016, 08:31 AM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Default Blocks, Billet Main Caps, Y Bridge
I have planning on building a engine for a projects, but I haven't had time to get remotely close to finishing the vehicle. So some of the parts I have been saving, I would like to move them.
LB7/LLY Y Bridge, it has a 3.5 inch inlet with tabs that can keep your boost tube from blowing off. $150 Shipped
A set of No Limit MFG billet Main Caps, They came out of engine some valve issues that damaged a piston. $550 Shipped or $700 with the matching LLY block, it will need to be bored 20 Over.
A LB7 Block with stock main caps that needs to go 20 over as well. $250
LB7 crankshaft that could be sold with either block for a extra $200
LBZ/LMM rods 200 Shipped
I also have most for the rest of the parts to make complete engine minus the heads, turbo and injectors, So if anyone interested extras any of the above please let me know and we can put together a deal.
__________________
2001 2500HD Red on Black.
ATS Dual CP3, ATS intake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #2
Old 10-18-2016, 09:44 AM
Slowmax's Avatar
Slowmax Slowmax is offline
Build what others' won't
Default
Sell the crank separate?
__________________
02 Silverado 4 inch turbo back exhaust with muff, A.E.M intake with cone filter, EFi live.
  #3
Old 10-18-2016, 09:54 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Pic of the bridge?
__________________
07 crew long classic, stock minus some pretty parts
Thanks to everyone on this forum who has helped me and those whom I bought parts from.
Special thanks to Evan, James, Russell, Mark and all the others I'm forgetting.
  #4
Old 10-18-2016, 10:57 AM
<<<IT WORKS
Default
Quote:
I would prefer not to, but if both blocks go without, then I would consider it.
Quote:
Originally Posted by clrussell View Post
Pic of the bridge?
Sorry, I tried posting them earlier but it wasn't loading them.
File Type: jpg tmp_30458-IMG_20161018_08161078513865.jpg (180.0 KB, 257 views)
__________________
  #5
Old 10-18-2016, 02:29 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
Wehrli made the bridge
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #6
Old 10-18-2016, 05:00 PM
<<<IT WORKS
Default
Quote:
Thanks for that, I couldn't remember if it was or wasn't, so I didn't want to false advertise it by accident. It is a nice piece, but its really only will work early with a remote mount single or wehrli's side mounted primary set up.
__________________
  #7
Old 10-19-2016, 02:21 PM
<<<IT WORKS
Default
Bump, Someone needs to start a build, I have front and rear covers, oil pans, a bunch of other stuff that can make a build easy and quick without your truck being down for a long time.
__________________
  #8
Old 10-29-2016, 06:54 PM
<<<IT WORKS
Default
Bump
__________________
  #9
Old 12-28-2016, 01:20 PM
<<<IT WORKS
Default
Bumping this up and adding some more stuff
Set of LBZ intake runner, 60 Shipped
Complete LLY HP fuel system with sensor for 300 Shipped
LLY injector hold downs with bolts 60 Shipped
Stock S366 cover and wheel, it has a v band cut on to the cover with an adapter for 2.5 inch boot. 60 shipped
2001 and maybe 2002 ABS pump/Brake control module. 200 shipped
I also have the electric moter for the ABS pump. 60 Bucks Shipped
__________________
  #10
Old 03-02-2017, 11:25 AM
<<<IT WORKS
Default
Bumping this up
__________________
  #11
Old 03-02-2017, 11:29 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
Just wondering who's y bridge that is?
  #12
Old 03-02-2017, 12:41 PM
ikeG's Avatar
Oughta Know Better
Default
Quote:
Werhli
Sent from my XT1585 using Tapatalk
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #13
Old 03-02-2017, 03:15 PM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Default
Still have LLY block with billet main caps?
__________________
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #14
Old 03-02-2017, 08:40 PM
<<<IT WORKS
Default
Yes I do Zak.
__________________
  #15
Old 09-18-2017, 07:38 AM
<<<IT WORKS
Default
Well its time to bump this up again and clean out the shop for a new set of injectors for my truck.
Werhli LB7/LLY Y Bridge, it has a 3.5 inch inlet with tabs that can keep your boost tube from blowing off. $150 Shipped
A set of No Limit MFG billet Main Caps, They came out of engine with valve issues that damaged a piston. $550 Shipped or $700 with the matching LLY block, it will need to be bored 20 Over.
LBZ/LMM rods $200 Shipped
LBZ intake runners-$70 Shipped
2004.5 Chevy 2500 ECSB 4WD frame only-$500
Front Axle from the frame above, was in a engine fire, not sure what shape its in-$250
3 inch in and out duel core Air to Water inter-cooler that hangs off your transmission cooler bracket-$400
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
