Old 07-25-2017, 01:29 PM
Gman327 Gman327 is offline
FNG
Default Lb7 neutral drops
Trans or tc has been acting up for a while now, under heavy acceleration truck will go into neutral from the 2-3 shift and reengage once I let off the throttle. Only code I got for it was p0776 once, tc was out a few months ago looked good at the time tailshaft is tight now. Ordered new speed sensors waiting for them to come in now speedo was jumping around a bit last winter any chance this could be my problem, any advice is greatly appreciated.
03 lb7, built trans, airdog 165, ats co-pilot, banks big head, snow meth inj, ppe tuner, s475 over stock maf deleted, bag of parts cp3
Old 07-25-2017, 01:55 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Could also be a blown out C3 piston.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 07-25-2017, 02:54 PM
FNG
I hope not sounds like an overhaul if that's the case. Seems to do it with ease in 4wd also not sure but could be 2nd gear in 4hi and spin in loose will cause it. Did drain and filter 2k ago fluid looked fine and seems fine now going to drop the pan tomorrow and see if there's anything obvious to me. Any and all suggestions greatly appreciated.
Old 07-25-2017, 03:08 PM
FNG
Going to bypass the copilot also seems like the throttle position sensor on it could be acting up the lights on the copilot seem to be erratic, though the wire looks fine.
Old 07-25-2017, 04:02 PM
Awenta's Avatar
Awenta Awenta is offline
Did I hear copilot?
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
Old 07-25-2017, 04:34 PM
torqued2dmax's Avatar
Is it an ATS trany with 5 Star ? and what did you look at when you pulled converter ? who knows what question might spark a fix to your problem .Good luck!
05 CC/LB DRW LLY Allison
Old 07-25-2017, 04:41 PM
Mike L.'s Avatar
I bet the C3 clutches look like an accordian.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 07-25-2017, 05:06 PM
FNG
Nadp heavy hauler with co pilot
  #9
Old 07-25-2017, 05:12 PM
FNG
Funny thing is is shifts fine runs awesome till I lay on it hard down low and it lets go into neutral. But I have no clue about the Allison, cracked the rear case a few years ago only time I had it out
  #10
Old 07-25-2017, 07:17 PM
Mike L.'s Avatar
You didn't get much of a trans.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #11
Old 07-25-2017, 07:24 PM
FNG
Sad thing is it's the second one too from warranty added the deep pan and big cooler too
  #12
Old 07-25-2017, 07:51 PM
Awenta's Avatar
Polishing a turd
How's the truck run? Sounds like a smoke machine. Ppe box and no maf?
Arek
EFI by Kory
  #13
Old 07-25-2017, 08:37 PM
FNG
Yea it's a peice of shit forsure but my trans problem proceeds my compounds I don't know everything I'm here for help the truck isn't my dd and it runs mint maf code only gets thrown on ign cycles!
  #14
Old 07-25-2017, 08:39 PM
WVRigrat05's Avatar
Wound for sound
You have an Allison that neutral drops?! I want it!
Reger
100k miles. Piston eater.
  #15
Old 07-25-2017, 09:11 PM
FNG
Sold! Not nearly as cool as it sounds needs a tranny lol
