  #1
Old 10-06-2017, 05:25 AM
Renaldo Renaldo is offline
FNG
Default Seeking Wisdom on LB7 Injector Job...
Duramax LB7 2004, 150K, needs new injectors. Dealer wants $6500 so...I figured I would mess up the job myself and save $$.
This will be the second injector job on truck...first done by dealer under warranty at about 100K with "new improved injectors...(sigh)".
I am a shade tree mechanic, seeking wisdom. Hoping to get another 50K out of truck.
My plan is to replace injectors, all related seals/gaskets and the eight high pressure fuel lines (hoping to avoid getting debris in new injectors).
Question: Should I replace injector cups (even if they don't lift up)?
Should I change out anything else while I am in there even if there is no apparent problem. Fuel return line? Other?
I would rather spend a few hundred more and do it right.
Thanks for your help.
  #2
Old 10-06-2017, 05:39 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
You do not need to replace all the cups. However you should remove all of them and clean the hole, replace o rings, and reseal. No need for new return lines. I would recommend 2 new bolts for the return lines at the head as I've had a few twist in half. Also, the factory go return line bolts at the injectors are a major pain. You'll be lucky if you don't round them off. Make sure you have a GOOD QUALITY 5mm Allen head socket. Flat ended. Not ball ended. My recommendation would me Merchant Auto upgraded return line bolts. I got sick of my factory ones cause issues and got them. They are great. Double the head on them so that can easily be properly torqued.
__________________
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #3
Old 10-06-2017, 06:42 AM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Default
We have the install instructions/torque specs here to complete the injector job. We also have all kinds of different kits with the injectors at unbeatable prices. Let me know if I can help.
__________________
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
  #4
Old 10-06-2017, 06:53 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Definitely talk to Brent!
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #5
Old 10-06-2017, 07:03 AM
JRein JRein is offline
Aircraft Mechanic's Hero
Default
Quote:
X2
Sent from my SAMSUNG-SGH-I747 using Tapatalk
__________________
-J.R.-
_______________________________________________
2004 LB7 2500HD 4X4 CCSB
Mods: LDS 63.5mm turbo, 45% SAC injectors, Built Allison, Mishimoto IC piping, EFI Live, Modded stock intake, Modded intake horn, Intake heater Deleted, Water separator/10 micron/Lift Pump, CAT Filter, 3" down pipe, MBRP 4", Incognito tie rods, High Idle, MA pump rub kit
Tunes by Idaho Rob
Trans Kit from Evan @ Limitless Diesel
  #6
Old 10-06-2017, 07:07 AM
zakkb787's Avatar
<thatís not me...
Default
X3. Best prices and best service.
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #7
Old 10-06-2017, 10:22 AM
FNG
Default Thanks guys!
Thanks and I guess I will "talk to Brent"! I will buy some primo hex 5mm bits.
  #8
Old 10-08-2017, 06:35 PM
duramax on fire duramax on fire is offline
Default
I'm a shade tree mechanic also. Bought my first dmax lb7 and within 5k miles I was going injectors. It's an easy job. Just pray you don't have any valve cover bolts round out. Yes you need a good set of Allen head sockets. If the return lines strip vise grips will break them loose. It's really not a bad job. The pain is pulling and resealing the injector cups. In my opinion. These lb7 injectors are funny. I have a friend that bought an 03 new and he's still on factory injectors. 190k miles.
  #9
Old 10-11-2017, 01:18 PM
warriorcustoms warriorcustoms is offline
FNG
Default
Grab the SAC 45s from Brent & get a single tune to clean em up!!! It adds a little power & MPGs from what Ive collected... I was gonna go LLY Topend but these injectors sound like the ticket for LB7s
  #10
Old 10-11-2017, 09:44 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
Should be sweet, really happy with my 65ís from Brent, picked up around 1.5mpg so far
__________________
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #11
Old 10-12-2017, 06:30 AM
Brent@LDS's Avatar
Default
The SAC injectors are the way to go!
__________________
Phone: 920-361-7700
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
