Old 10-12-2017, 08:46 AM
2012 DMAX 2012 DMAX is offline
Gearhead
Default What's involved in changing #4 Glow Plug ?
Recently, two days into our vacation my check engine light comes on. All guages and fluids check normal. We are in the middle of nowhere in Arizona but luckily we find an Auto Zone that is close. They scan the truck and get a code for #4 glow plug. So the rest of the trip I plug in the engine heater at night and all is good.
Now that we are back home, how difficult is changing this glow plug ? Do I need to remove the inner fenders and work through the wheel wells ? The part was only $12 and change.
BTW... which is the #4 cylinder on a Duramax ? 2012 Chevy 2500 Silverado 4x4
Old 10-12-2017, 08:53 AM
Chevy1925's Avatar
if you bought an autozone plug, take it back and buy a factory plug. they last much longer than those junk cheap ones.
cyl 4 is second cyl back from the front of the engine on the driver side. i would remove teh inner fender to change it. it will make it easier. pulling the tire will help too.
dont fret over a bad glow plug. the truck will start just fine even in cold cold weather with one bad plug.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 10-12-2017, 03:43 PM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Sky View Imaging
A little tip for changing glow plugs, do it with the engine warm.
06 Chevy LBZ
Olympic White • Built Motor/Trans • Bullseye s375 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White • Brown Dakota Leather • Premium/Cold/Smoker Pkg • LED AEs • MTec D1S • 50% tint
2000 Buick Regal GS
Bright White • Lowered • Homemade CAI • 4500K HIDs • Supercharged • Beater
Old 10-12-2017, 04:41 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
I jus pull the intercooler tube and you'll prolly have to take the steering shaft loose. Go from the top. 30-45 min job
01 ext cab, Billet ihi, trans with g converter, sac 45s, tap shift, lots of black, everything built by myself with help from some of the best in the buisness.
Thanks to everyone on this forum who has helped me and those whom I bought parts from.
Special thanks to Evan, James, Russell, Mark and all the others I'm forgetting.
Old 10-12-2017, 05:09 PM
Awenta's Avatar
Awenta Awenta is offline
If it’s rusted bad there’s an air hammer attachment that works well. I second doing it with a warm engine
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
Old 10-12-2017, 07:56 PM
AZlml's Avatar
AZlml AZlml is offline
$12 seems really cheap. The stealership charges quite a bit more for oem. There's also a chance that more will go out in the near future if they are all original or changed at the same time.
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
Old 10-13-2017, 04:30 AM
FC5452's Avatar
FC5452 FC5452 is offline
If you don’t want to mess with it take it to the dealer and have them replace it under warranty. There is an extended service on this for the 11-12 LML’s
15114 - Special Coverage Adjustment - MIL Lamp On / Glow Plug Heater Inoperative
If not the part number for the glow plugs is 12639701
LML- With some Stuff added
Old 10-13-2017, 04:37 AM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Coming from experience I would do the whole side while your in there.
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
  #9
Old 10-13-2017, 06:18 AM
OregonDMAX's Avatar
NOT IN OREGON
All 8 and just be done with it. My brother did 1 and then another popped up so he did that one then another popped up so he did the other 6. Just do them all.
Sean
02 CCSB
Moonshine tunes, MikeL trans, Exergy Sportsman, 4/6 drop, LML 20's/420's
  #10
Old 10-13-2017, 06:53 AM
Gearhead
Thanks everyone for your input. My 2012 truck just hit 50k miles on this trip. Is it still covered under the extended warranty for this ?
  #11
Old 10-13-2017, 06:55 AM
FC5452's Avatar
10 years or 120,000 miles
  #12
Old 10-13-2017, 08:10 AM
AZlml's Avatar
Good info thanks
Bryan
11 CCSB 4x4
  #13
Old 10-14-2017, 01:48 PM
Gearhead
That's excellent news. Thank you !
  #14
Old 10-14-2017, 02:25 PM
FC5452's Avatar
Welcome
  #15
Old 10-14-2017, 04:40 PM
tkenn21bb tkenn21bb is offline
FNG
Depends on what your time is worth. It wasn’t worth it for me to waste time going to the dealer, get a loaner, go back to the dealer, etc for a $18 part and a couple hours of time. I would have wasted a lot more than that driving around during work hours. Changed the plug myself on the weekend. It’s all relative.
