  #1
Old 02-24-2018, 02:40 AM
Gmccrewcab2000's Avatar
Gmccrewcab2000 Gmccrewcab2000 is offline
FNG
Exclamation 2000 2500 350 to duramax swap? How hard could it be?
I'm looking for info on swapping the crappy 350 that's in my 2000 obs 2500 to a duramax. what all is involved in the swap? Putting the engine into the truck is a non issue just the electrical side of it I'm not too sure how to make work. Any info would be awsome.
  #2
Old 02-24-2018, 06:14 AM
TheBac's Avatar
TheBac TheBac is offline
Default
Moved into Repower/Transplant section. Start looking thru this section and reading. There are a few threads here on people's OBS conversions.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #3
Old 02-24-2018, 02:40 PM
blackLTZ's Avatar
blackLTZ blackLTZ is offline
Default
Would like some info on this I also have a 350 that I want to swap for a dmax
__________________
2012 cc/sb z71 LTZ duramax, EFI live by PPEI ,maxx effort, Fass150, 6.5 bds, turbo Back Exh, S&B intake,
  #4
Old 02-24-2018, 05:55 PM
LCAC_Man LCAC_Man is offline
Gearhead
Default
it's a lot, you'd be way better off buying a duramax truck...the electrical / computer systems are completely different even to get to the early LB7 version...if your truck was 2 years newer(and had a 6.0 vortec) it'd be a different story..
__________________
Len Barron
2000 Express 155"wb Passenger Hightop
  #5
Old 02-28-2018, 03:15 PM
FNG
Default
So swap the dash as Well then? Buying a different truck isn't an option I don't like em.
  #6
Old 02-28-2018, 04:37 PM
weazel's Avatar
weazel weazel is offline
Default
Either have someone wire up the standalone harness for you or look up wiring schematics and wire one up yourself. Not hard, just time consuming. Also, to make the gauges work on the truck as it sits now, just move the old sensors out of the gas engine and install them on the duramax engine... no real need to swap an entire dash or gauge cluster/adapt to older dash if you don’t need to...
__________________
88 Chevy 1/2 ton- LB7 conversion project
93 Chevy K3500- CR Cummins conversion project
05 Chevy LLY 5" ex, EFI DSP5
  #7
Old 03-01-2018, 06:43 AM
Gearhead
Default
Quote:
I agree, go stand alone and use an Edge CTS2 Monitor to see what your stock dash won't display. If you're going LBZ 6sp Allison you can wire up a momentary switch with the correct resistors to use tapshift. Tow/Haul mode is tougher to solve, I'd just run a mild tow tune for daily driving or get EFILive DSP5 and have selectable tunes..
http://www.standaloneharness.com/duramax.html
__________________
Len Barron
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
