  #76
Old 08-25-2016, 08:43 AM
Burn Down's Avatar
Burn Down Burn Down is online now
Default
Quote:
Originally Posted by SmokeShow View Post
I thought the cruise control circuit ran through the BCM [also?] and needs feedback from the brake circuit as well?
You know... so it'll actually kick off when you hit the brakes.
Meh, who needs brakes?
But I bet your correct Mitch.
__________________
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB ole crappy, built eng, built trans, mpi twins
  #77
Old 08-25-2016, 08:50 AM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
Sweet build, considering doing something similar with an old farm truck 79 k20 single cab
Sent from my SM-G925V using Tapatalk
__________________
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #78
Old 08-25-2016, 12:41 PM
Tsmyth's Avatar
Tsmyth Tsmyth is offline
Gearhead
Default
Quote:
Originally Posted by tjb406 View Post
I have so many Questions. lol. i am also installing an lb7 in a chevy crew cab ,mine is an 01 lb7 and a 91 crew cab. i also am using the dakota digital gauges. im curious if the leads from the ecm for speedo and the tach are in a format that the aftermarket gages understands. i havent started the actual install in the truck yet i just got it striped down to bare cab now. i already have the whole 01 truck i bought it several years ago and now it is starting to get some really bad cancer on the body and the frame. i too was going to use an adapter for the 205 bought it and all,but have since decided to use the factory push button case and ford dana 60 hp instead. i still have all the shafts and coupling and infinately adjustable clocking adapters to sell now. i was planning on doing my harness myself but it is a small bit difficult to find the exact scematics that i need.
My speedo will be ran from the 205 transfer case. Dakota digital sells what you need to make that work. I havent installed it all yet....however, in the next few weeks I will be back on this project pretty heavy. My harness should be here in a few days. I'll post some pictures of it. I'm sure it's another stellar piece from Ben. I haven't seen his work in person but I've dissected many harness pictures and talked to several people, his are, from what I can see, the best.
  #79
Old 10-26-2016, 06:39 AM
Tsmyth's Avatar
Gearhead
Default
I've been working on swapping cabs recently, I've received my harness from Ben and it looks amazing, should look very clean in the engine bay. After I finish cutting up my donor cab to make it fit the engine, I'll be putting it all together.
  #80
Old 10-26-2016, 06:47 AM
Tsmyth's Avatar
Gearhead
Default
A picture of the harness.
  #81
Old 10-26-2016, 06:49 AM
DURAMXD's Avatar
DURAMXD DURAMXD is offline
BOB SAGET!
Default
Super excited to see you got your harness and to see this thing going!
__________________
Wayne
2003 2500HD RCSB 2WD: Built trans, PPEI tuning
2006 2500HD ECSB 4WD: Danville 3794 STG2R, built trans
2006 3500 CCLB DRW 2WD
  #82
Old 10-26-2016, 10:55 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
Project is looking great!
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #83
Old 11-14-2016, 10:05 AM
jbmatth jbmatth is offline
FNG
Default
For some reason I can't view the photos even when logged in. On another note I have my lift installed now so give me a call when you are ready to swap the cabs over.
JB
  #84
Old 01-28-2017, 07:09 AM
bigdisplay442 bigdisplay442 is offline
FNG
Default
I've got an 1988 c/c dually 2wd that i just started my Duramax conversion on.
It appears in your core support pic that you mounted the oem intercooler behind the core support.
If so, did this still allow room for the radiator And factory cooling fan to fit as well.?
Thanks, chres
  #85
Old 02-21-2017, 08:13 AM
Tsmyth's Avatar
Gearhead
Default
Yes, I used oem intercooler and radiator. There was plenty of room for the fan.
  #86
Old 04-28-2017, 03:32 PM
Tsmyth's Avatar
Gearhead
Default
I've had the truck together for a couple weeks now, it runs remarkably well, it will break the tires loose in 5th gear. I have the trans pulled right now to send the clutch back to south bend......
  #87
Old 02-10-2018, 07:26 PM
Tsmyth's Avatar
Gearhead
Default
I havenít posted here in a while, Iím on a swap page on fb quite a bit, if anyone is interested in it, itís Gm Squarebody Duramax Swap on Facebook. At any rate, since my last post on here, I put the clutch back in, south bend was great with reworking it...quick turn around time and cost like 100 dollars I believe. Anyways, the Dana 70 that was in the truck....well, it was ruined not long after the clutch was reinstalled, too many 4th gear pulls ripped the ring gear teeth off of it....so I put a 14 bolt in it out of a 94 Chevy dually, seems to be holding up nicely. I was also running the clutch master cylinder from a square body, it ended up being a no go, had to modify the firewall and pedal to accept a duramax master cylinder.
  #88
Old 02-11-2018, 07:44 AM
Schwinn68's Avatar
Schwinn68 Schwinn68 is offline
little gearhead
Default
Any finished pics? Very cool project. Would make an excellent welding rig
__________________
Ben
05 LLY Alli
the "Dream Crusher"
Proud member of Pipefitters Local 597
certified mig tig and stick pipe welder
thanks to Bobo_Team Twisted_Danville Performance_Big Dipper_Sandwich Crew and Todd
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
