  #1
Old 09-16-2017, 09:32 PM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default Lb7 no start story
Driving home on Friday my truck died, quickly cracked open water separator to see if I had fuel at the Airdog. Nothing came out, figured my fuel gauge went bad and I had an empty tank. Got fuel but no luck, had it towed home and dropped tank and it was between empty and 1/4. Water separator has rust in it, never in my 7 years with this lift pump on have I ever gotten any water out of it and I check it fairly regularly.
So I guess I need a water separator at minimum, pump sounds so-so but it's held up great without a single issue all these 7 years, it's an AD165.
If the water separator doesn't fix it then it's probably the pump so I'll get it warrantied and I figure I'll add a sump and a new feed line from the pump all the way to the cp3. From the factory there are some pretty ****ed up lines, a return was actually sandwiched between the frame and tank and practically crushed flat. I know it's factory because I have the vehicles entire GM service history and I bought it only 190 miles after it's last visit to the dealer.
Anything else I should do while the tank is out and I have the truck apart. I've had a p0089 for a good while figured all new fuel lines was in order. I know it needs a cp3 and regulator i got a pretty sweet fuel lope at idle and data logs show it's out of fuel by the 1/8th mile on a 1/4 pass.
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
  #2
Old 09-17-2017, 07:36 AM
aashton1206 aashton1206 is offline
Default
I have a 165 as well and I warranties a new pump a year ago. Great service, and the pump works great. No I had a recent issue will oem fuel lines collapsing so I ordered more fuel line from pure flow and I cut out all the quick disconnect fittings and used clamps. All new 1/2 line then the return line between the hard lines up by the firewall on the driverside was collapsed. So I did that to with some line I got from auto supply. Kind of just a peace of mind. On another note, the reason I replaced the return was I had a cascading fuel rail pressure. First I thought it was the fprv, it wasn't, the hardline tuning to the back of the block that was a return line was broken and priced together with fuel Line. That wasn't it either, long story short I found two kinks in the soft line and that was causing it. Got all new stainless lines from merchant and hose from pure flow.
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Platinum AGM Duralast, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
  #3
Old 09-17-2017, 08:06 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
You could do a billet pickup while you're in there
__________________
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #4
Old 09-17-2017, 09:54 AM
OregonDMAX's Avatar
NOT IN OREGON
Default
Quote:
Yeah I'm going to run a new feed line for sure I've found a few rubber flex sections that are questionable at best since I've dropped the tank. Found a slightly linked hard line too so I'll prob just eliminate all of the hard lines completely.
__________________
Sean
02 CCSB
  #5
Old 09-17-2017, 09:55 AM
OregonDMAX's Avatar
NOT IN OREGON
Default
Quote:
I'm going to do a sump since the tank is empty and out
__________________
Sean
02 CCSB
  #6
Old 09-20-2017, 04:29 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
Replaced water separator, I'm getting fuel up to the disconnect up at the firewall by the gpcm, not getting fuel to the cp3 or the cp3 took a shit and won't make rail. FML
__________________
Sean
02 CCSB
  #7
Old 09-20-2017, 04:42 PM
JRein JRein is offline
Aircraft Mechanic's Hero
Default
Have you checked fuses and the edu/ign 1 relay?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
__________________
-J.R.-
_______________________________________________
2004 LB7 2500HD 4X4 CCSB
Mods: LDS 63.5mm turbo, 45% SAC injectors, Built Allison, Mishimoto IC piping, EFI Live, Modded stock intake, Modded intake horn, Intake heater Deleted, Water separator/10 micron/Lift Pump, CAT Filter, 3" down pipe, MBRP 4", Incognito tie rods, High Idle, MA pump rub kit
Tunes by Idaho Rob
Trans Kit from Evan @ Limitless Diesel
  #8
Old 09-20-2017, 05:38 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
Yeah, I got a blown 40a fuse but it's for trailering shit
__________________
Sean
02 CCSB
  #9
Old 09-20-2017, 05:54 PM
Default
Quote:
Are you sure?
The 40s on my 04 are ign(s) and blower
__________________
-J.R.-
Tunes by Idaho Rob
  #10
Old 09-20-2017, 06:02 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
Stud #1 is trailer wiring, I should have mentioned that was the one it was
Also my fuse box is completely different, complete wiring changes in 03
__________________
Sean
02 CCSB
  #11
Old 09-20-2017, 06:04 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Honestly, it sounds like your CP3 died.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #12
Old 09-20-2017, 06:26 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
Quote:
That's what I was hoping and not hoping, I've had a p0089 for about a year but you know how that goes it could be basically anything in the fuel system.
I did get a few surges over the past few months maybe once every 2 weeks it would randomly drop off and about 2 seconds later I'd get fuel again
The question is how do I test do determine if it's the cp3 or regulator obviously if it's the cp3 I'll do both but neither are in the budget
Fwiw the cts won't read any rail or any other pressures on an 02 or atleast mine
__________________
Sean
02 CCSB
  #13
Old 09-20-2017, 06:35 PM
TheBac's Avatar
Default
Just a thought, but could the gearpump on the back of the CP3 have gone bad? Is that even possible?
__________________
Tom
  #14
Old 09-20-2017, 06:59 PM
zakkb787's Avatar
<thatís not me...
Default
Forgive me if I read this wrong, but my cts reads both rail and desired rail on my 02
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #15
Old 09-20-2017, 07:14 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
I don't even know, maybe it imploded like a cp4
I don't even know what to do not being able to see any rail pressure is what's stumping me, too many variables, is my cts working, or is my pump shot... Did the pump shaft shear off... I don't even know ow where to begin, I do know I have fuel at the cp3 on the low pressure side
Mine won't read anything, is it because the pump is fried... Who knows
__________________
Sean
02 CCSB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
