  #31
Old 06-17-2012, 10:39 PM
Sledhead's Avatar
Sledhead Sledhead is offline
Mountain Pass Machine
Default
I'm heading for home from a great tour of Alberta
The highlight was a tour of DPS in Calgary (thanks Kevin) and Curtis Halvorson gave me a personal lesson on D'max builds amongst other things
Tomorrow I'll hit the Crowsnest Pass from the steep side
__________________
03 CC DRW 4X4 EFI Live, EPR Twins GMax-5
  #32
Old 07-07-2012, 11:31 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Quote:
Originally Posted by hondarider552 View Post
What I do not get, is that some people on DP, think that oil cooling, and coolant cooling, are two different issues, and AREN'T related...
Now lets not tlak about it much, or Randy_the_slut will come over here pounding his hairy chest
I hope he does.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #33
Old 08-20-2012, 01:05 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is offline
Book 'em, Danno!
Default
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #34
Old 09-05-2012, 01:36 AM
One Bad Duramax's Avatar
One Bad Duramax One Bad Duramax is offline
FNG
Default
Quote:
Originally Posted by Sledhead View Post
I am very pleased with the results so far
I climbed the Coquihalla yesterday, it's about 10 miles at 5-6% and it goes to 6-7% at the top. I had cruise on about 65 mph until the steep part and oil temp was about 205*, oil pressure and coolant were perfect.
I got on it at the snowshed where it gets steeper and crested the top about 85 mph, oil temp 234*, with a slight drop in oil pressure (down to 380 Kpa from 400 Kpa?) and I don't think the coolant temp moved off the thermostats. The fan never cycled and my max egt was 1195*
I know without the cooler my oil temp would have been 50* higher. The conditions were pretty ideal though; about 50*F at the top and misting rain. I had my heavy slide in camper but no trailer this time.
205? wow my truck has never gone over 190 with a 14k load on it and I live in California with plenty of hills
__________________
http://www.8-lug.com/features/chevy/...cab/index.html
Current Sponsors: SoCal Diesel ,SDP,Smitty Built ,Offroadledbars,Merchant Automotive,Ultimate Truck Gear,Rhino Linings ,Interco Tire Corporation,S&B filters,,Mile Marker,Optima Batteries,Mag-Hytec,818 Autosport, Setrab,Silverline,Titan Fuel Tanks,AirDog,Power Stop,VIAIR CORP, Mean-Green.com Yukon Gears, ISSPRO, Magnaflow
  #35
Old 09-05-2012, 04:56 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
I dont believe that..
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel
Tailgate Member #1 I prefer the backdoor
  #36
Old 09-05-2012, 06:17 AM
kivetts04dmax's Avatar
kivetts04dmax kivetts04dmax is offline
Default
sub'd, a cooler running truck is a happy truck!
__________________
2006 CCSB LBZ -FPE Billet S472 w/HSP Kit, Studded, Plugged, Deleted, Levi's Blankets, 3" Drop Shackles, OLs removed, Braces, Kryptonite Front End, Electric Fans, Suncoast GMAX6, MA Trans Brace, Pump Rub, Transgo, MagHytec Pans, Magnaflow, Rigid, Alligator, PPEI Tunes, 305/50 Nitto 420s, 20x10 Fuel Couplers, Trac Bars by LWATSON
2004 RCLB ZF6 LLY -SOLD
Billet S472, Southbend DD
2004 CCSB LLY -SOLD
  #37
Old 09-06-2012, 05:58 PM
FNG
Default
I highly doubt my isspro oil temp gauge has been lieing to me. The only time my oil went over 200 was when i spun the main bearings it went to 280
__________________
  #38
Old 09-06-2012, 06:36 PM
LBZrcks's Avatar
LBZrcks LBZrcks is offline
Default
Quote:
Where's are you reading temp from?
__________________
17' Denali HD CCSB Z71 Stock
Previous Dmax's
06' Chevy 2500HD CCSB 4x4, EFI Live, PPE GT40/GTX45 Twins, Socal 60s, Mike L. Trans
08' Sierra LMM CCLB Z71, Mike L. Trans, EFI Live, McRat Racing Tune 12.97@102.73
06' Sierra LBZ RCLB 4X4, Mike L. Trans, EFI Live, McRat Racing Tune 12.25@111.30
06' Chevy LBZ CST 9-11 Candy Red and Chrome
04' Chevy LB7 FabTech 8" Suncoast III w/TTS Converter
  #39
Old 09-06-2012, 06:49 PM
Getting faster
Default
You will never see 190* oil temp towing 14k I promise you that. Oil coolers are good, but not even my cooler drops my towing temps to that, and I have an extra gallon of capacity. Towing, I saw 225*, and went no higher.
__________________
"OldManTan"
15 Cruze diesel
  #40
Old 09-06-2012, 09:51 PM
FNG
Default
Quote:
It's connected where isspro instructions recommended it on the oil cooler , I towed Starwagons make- up trailers and generators for the studios in LA in traffic for over 6 years with my truck and it never got that hot, even towing to Vegas. Idk once I get my truck back together I'll give you guys the 411 , Since the motor is out still.
http://www.starwaggons.com/site/inde...nd_enclo/#tabs here's info on the trailer so you know i'm not bsing
But maybe the location that isspro recommended is not a good location?
Input would be good to know once I get the truck back up and running, since I'm putting a twin kit on the truck
__________________
  #41
Old 09-07-2012, 04:55 AM
Getting faster
Default
......where does isspro say to mount the probe?
the port on the top of the oil cooler (correct spot) will read the highest oil temp we see in the engine. The port on the bottom, shows the oil temp after it goes through the oem cooler. (we dont need to watch this)
__________________
"OldManTan"
15 Cruze diesel
  #42
Old 09-07-2012, 05:20 AM
adrenaholc1's Avatar
adrenaholc1 adrenaholc1 is offline
Default
Sounds like he's seeing the after oil cooler temp. Wouldn't the best place to read temp be the pan? I guess before cooler would be the same?
__________________
*******FOR SALE*******
06 LLY CCSB SRW 2500HD 4WD BLACK N TAN
BOUGHT 1/28/11-182,000 CURRENT 4/2/14-139,000
68MM CHEETAH W/3.5-4" DOWNPIPE BY FPE
DIAMOND EYE 4"STRAIGHT EXHAUST
FPRV SHIMx2 EGR BLOCKED PCV RR
AIRDOG II BUTCHERED AIRBOX RES PLUGGED
TRANSGO JR ALLI DEEP PAN
285/75/16 TOYO OPEN COUNTRY M/T
EFILIVE V2 W/DSP5 BY ATPTRUCKS.COM...THANK YOU ROB...GREAT WORK
189,000 13.10@100.2 5-2-11 STOCK CHARGER
193,000 13.08@100.6 7-8-11 68mm
483/888 DYNOJET INERTIA DYNO
97 12V RC/LB 2WD RUSTY W/DENTS 316,755
NV4500 STIFF CLUTCH 4.10
LIMO TINT 22MPG
FUTURE MODS: TRANSPLANT
$$$$FOR SALE$$$$
88 WELLCRAFT CONCEPT 23' SPORT CUDDY
600HP GENVI 502 STOCK IRON HEADS
CUSTOM CAM 980 HOLLEY MERLIN INTAKE
MSD STAINLESS MARINE EXHAUST
BRAVO ONE 23P HYDRO 72MPH
  #43
Old 09-07-2012, 05:25 AM
Default
Should rewire factory water temp in cluster to read oil temp and adjust hot engine warning alarms via efilive. Is this possible. I just did this on my boat engine. I had oil press. And water temp gauges and swapped them so I was reading water pressure and oil temp. Just makes more sense for the application.
__________________
LIMO TINT 22MPG
$$$$FOR SALE$$$$
  #44
Old 09-07-2012, 05:46 AM
Default
Brian what kit do you have?
__________________
2004 CCSB LLY -SOLD
  #45
Old 09-07-2012, 05:33 PM
Getting faster
Default
overpriced Killerbee kit.
__________________
"OldManTan"
15 Cruze diesel
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
