  #1
Old 11-20-2017, 04:09 PM
WACATTACK WACATTACK is offline
FNG
Default Pegged oil pressure gauge
2002 Duramax oil pressure gauge started bouncing and now reads way past 80#'s when running and just over 80#'s when off.
  #2
Old 11-20-2017, 04:48 PM
frankenstien's Avatar
frankenstien frankenstien is offline
Default
Check actual oil pressure with a scan tool or mechanical gauge and verify actual oil pressure reading, may be a bad sensor, but the stepper motor on the gauges are a very common fail point
__________________
2005 ECSB LLY
Danville Tuned
5'' exhuast
Fass 150
Built Trans w/SC1058
Bumpers built by me
  #3
Old 11-20-2017, 04:59 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Quote:
Not on an 02. Probably the ending unit.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #4
Old 11-20-2017, 05:40 PM
Default
Quote:
Learn something new every day, well disregard that part
__________________
2005 ECSB LLY
Danville Tuned
5'' exhuast
Fass 150
Bumpers built by me
  #5
Old 11-20-2017, 06:29 PM
FNG
Default
TheBac, do you mean the oil sending unit instead of ending? Not making fun, just verifying.
  #6
Old 11-20-2017, 06:52 PM
TheBac's Avatar
Default
Yes. My bad.
__________________
Tom
  #7
Old 11-21-2017, 10:18 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Stepper motors didn't start until 03 in full size trucks. Up to 02 they used air cores which rarely fail. I would suspect the oil pressure sender which is a black plastic sendi,g unit about 3 inches long and an inch in diameter screwed into the front lower drivers side of the block into about a 75 degree angle adapter. Be carefull replacing it as you can over tighten it, and crack the angle adapter. GM has discontinued them, so if you crack it, you're stuck looking for a used part that was only used for 2 years. It will have a single wire plugged into it. Unplug it and the gauge should peg over, ground it and it should read 0 oil pressure.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #8
Old 11-21-2017, 02:29 PM
TheBac's Avatar
Default
RockAuto has them in stock. Same sending unit as my Aurora had.
__________________
Tom
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
