  #16
Old Yesterday, 01:24 PM
1sgkarlthomas 1sgkarlthomas is offline
FNG
Honestly never thought of putting it in the freezer simple solutions for a simple mind. Thanks Dave
  #17
Old Yesterday, 01:39 PM
torqued2dmax's Avatar
Dont degrade yourself , you served your country as did I , be proud of that fact ! Good luck with your truck !
05 CC/LB DRW LLY Allison
AFE Blade Runner ;DHD Big Air intake;DHD fuel block;DHD pcv reroute;MBRP 4 inch exhaust;DHD 3 inch downpipe; BD driver's side manifold; DHD pass side up pipe ;DHD 3 inch intercooler in and out pipes by Big Foot on & off road shop ; shimmed fprv; FASS fuel system; 5/8 inch pickup; FASS fuel filter delete; EFI live, 5 position switch 250 hp big tune by Crank it up ; built SunCoast Allison 1078 converter by Limitless Diesel; Sulastic shackles;ARP head studs; grade C gaskets; tig-welded water pump ;T stats; by Blackout performance; Merchant t case brace and pump rub kit;drive shaft 1480joints Greensburg machine,BDS Recoil traction bars , 5100s
