  #16
Old 02-16-2016, 12:00 AM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
I love this thread already. Reminds me when my sister called me for help with her car, a beetle , she said it just made a loud bang and started running really really rough that she pulled over. I get there and pop the hood... Looks normal then I look underneath and notice the engine is about 2 inches off the ground.... Motor mounts broke and the engine just fell..... More stories with her and her cars than I can remember. Good times
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #17
Old 02-16-2016, 04:37 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Originally Posted by elliottw View Post
I've seen the leveling kit lathe too, they never understand why their cv's are wrecked and ball joints are shot either. This last one had both the swaybar end links broken off as well.
Those plastic end links break on a stock vehicle, let alone on something leveled
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #18
Old 02-16-2016, 04:40 AM
02greysixer's Avatar
02greysixer 02greysixer is offline
Originally Posted by chevyburnout1 View Post
I grabbed a picture of this one that came in today. I have never seen such a funky IFS lift setup. Like maybe it was the first one ever to come out. But it literally rubs on the sidewall of the tires! And they drove it like that! And to top it the truck was literally one of the most scariest trucks I've driven. Death wobble above 45mph, brakes beyond metal to metal, tires worn passed the threads, brake lines stretching and cracking. And having to blow in a disgusting breathalyzer at the same time which the customer conveniently didn't have any extra mouthpieces.
You can call the breathalyzer tech line and they'll give you a code or tell you how to bypass those things. They just need your business license number or something. I had a really nasty dodge with one that I refused to blow into so we figured that out.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
  #19
Old 02-16-2016, 05:28 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
I've bought 2 repairable/part out trucks that had a hole cut in the bed floor and a piece of sheet metal screwed to the bed floor to access the pickup/fuel sender on the fuel tank.
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #20
Old 02-16-2016, 05:43 AM
ikeG's Avatar
Oughta Know Better
Traded this Silverado 1500 in. Guy put 1" wheel spacers on without trimming OEM studs down to be flush with spacer . So all 4 wheels were seated only on the tips of the factory studs. The tires are half tread so you have to think that they'd been running like this for several thousand miles.
They also welded in a aftermarket muffler that must be 2.5" in/out so they got real creative with their reducers and welding. Possibly the worst welding I've ever seen.
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #21
Old 02-16-2016, 05:46 AM
Nathan.'s Avatar
Nathan. Nathan. is offline
The wiring photos make my OCD go crazy.
2005 Sierra CC LLY
2006 Jetta TDI BRM
2014 Harley Davidson Street Glide Special
  #22
Old 02-16-2016, 05:53 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
Me too, I'm an electrician so it makes my brain hurt to see stuff like that. It's hard to believe but I've seen WAY worse on customers boats. I'll have to start taking pictures...
  #23
Old 02-16-2016, 05:56 AM
ikeG's Avatar
Oughta Know Better
What about zip ties?
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #24
Old 02-16-2016, 06:25 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Isaac, where do you work?!
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #25
Old 02-16-2016, 06:55 AM
ikeG's Avatar
Oughta Know Better
www.griffithautosales.com
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #26
Old 02-16-2016, 08:13 AM
Chevy1925's Avatar
Originally Posted by 04jimc View Post
Check out the custom wiring job for the inoperable glow shift gauges in this LMM. What to do with extra boost gauge tubing?? Just pack it all in a wad and wrap around your brake pedal! Bada bing
It also had some junk homemade CAI that i regrettably did not take a picture of and it went in the dumpster. Cant remember the exact details on it.
buddy of mine in high school wired up some strobe lights in his truck like that. called me one afternoon asking if he wired it right. i hear him shut the door and go "oh shit, oh shit, OH SHIT, (click)". i was sitting there going, wtf??? he calls back a while later and goes "man i almost lit my truck on fire! wires got caught in the door and shorted to the body. i burned my hand ripping the wires off the battery". i go "how the hell did you get the wires caught in the door?". he ran them just like the pic, i just shook my head. even in high school i knew better....
James
best time to date: 12.39
Tailgate Crew Member #4
  #27
Old 02-16-2016, 08:42 AM
WVRigrat05's Avatar
Wound for sound
Do you come across many 99-02 7.3's?
Reger
100k miles. Piston eater.
  #28
Old 02-16-2016, 08:46 AM
ikeG's Avatar
Oughta Know Better
Sometimes but we wholesale stuff like that immediately.
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #29
Old 02-16-2016, 08:47 AM
WVRigrat05's Avatar
Wound for sound
Are most of them junk? Or just people just want them that bad?
Reger
  #30
Old 02-16-2016, 08:57 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
The wiring through the door is just inexcusable! There's plenty of spots to run it through the firewall. Smh
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12 sold
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
HTML code is On
