Old 03-29-2012, 09:19 PM
juddski88's Avatar
juddski88 juddski88 is offline
Here to Learn Tech..stuff
Transmission: Automatic
Default SRW Axle Length?
What is the length of a stock SRW axle from end of splines to the inside of the drive flange? Anyone who has one out to measure...
Thanks!
2001 Chevy 2500HD ECSB
Freedom Diesel SS Build "Sore Subject" - Big Dipper Trans kit, Raybestos clutches, DPC converter,HTT Custom Turbo, and several DTS parts.
I heard it on the internet..
Old 03-29-2012, 11:10 PM
RPM Motorsports's Avatar
smokinum
Truck: 07 CC/SB
Engine: LBZ 6.6L
35.5"
(Russ) 07 CC/SB Greystone 4x4 4" TC lift, Thanks-> MPI, ATP, Big Dipper. (11.80@115.8mph 1.62 60' Stock motor, Stock CP3)
"Just Cause": 07 LBZ EC 2x4, RPM Triples, SoCal stgII heads, SoCal injectors (Exergy), Hughes XP5 glide & lockup conv, trans brake, Gear Vendor drop box, RDL Xtream headers, coilover all 4 corners, narrowed 2x4 tube backhalf, four link, RJ Pro ARB, CM cage, diff narrowed 16", 33x17-16 Hoosiers on custom 16"x16" beadlocks.
Old 03-30-2012, 03:56 AM
juddski88's Avatar
Thanks Russ.
Talked to Branik Motorsports yesterday. They are going to be making me some dual splined axles for my 30 spline carrier in 300M material. I'm only ever going to be running SRW, so this is kind of an experiment at this power level. They said orders of this nature are about a month out....I'll keep you guys updated.
Old 03-30-2012, 08:15 AM
smokinum
Truck: 07 CC/SB
Engine: LBZ 6.6L
Who's carrier? Make sure they get the pressure angles correct. Yukon uses different then others iirc.
Old 03-30-2012, 08:24 AM
juddski88's Avatar
it is a Yukon grizzly carrier
Old 03-30-2012, 08:38 AM
smokinum
Truck: 07 CC/SB
Engine: LBZ 6.6L
their big spline stuff was where the issue was. Yukons spool would not work with others axles due to the different angle.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
