The vanjen style (Vibrant) connections allow for a decent amount of misalignment and will handle engine movement no problem, especially when used on each end of the pipe.What absorbs the engine movement to the intercooler plumbing?
Yes i believe they have like 12 degrees of movement if I remember right.
Yes. It's two flanges with o-rings and a sealing "ring" is inserted over them. The clamp sets the maximum distance between the flanges/stops them from coming out of the sealing ring as well as locating the sealing ring.Interesting. First time hearing about them. Do they just slip and slide around in a coupler with o rings to seal them ?
The new pinless style is nice, I am having these on my build as well Brendon.If you go on vibrants website they call them hd clamps motion raceworks makes them as well.. vibrant already redid them since they came out they don’t take the pin anymore probably because everyone would always lose them.
You can buy parts for them separately from ace race parts. They're interchangeable with Vibrant as well.They are very nice.. the only thing I don’t care for is they only come with aluminum ferrules you have the buy the stainless separately and always end up with a bunch of aluminum ones laying around.
