If y are just doing stock over 475 it would be decent, but what I have found and many others.. is that when you actually increase the size of the atmosphere turbo it actually ends up driving nicer as it is easier to "breathe through".
Think about it this way, essentially the atmosphere turbo is a restriction to the "valley" turbo so when you make it easier to pull air by increasing the size it makes drivability ALOT better, rather than making it work for it.
You might consider going with a smaller turbine housing than the standard 1.32 if you are doing it more for towing than all out power.
They also make t6 housings for the 87/80 turbine. That would be an excellent option for most people. As long as you make/purchase a kit with a t6 flange, you will have the flexibility to swap dozens of different s400 combinations out.On a LML I’m using a billet wheel 475 with 87 turbine and 1.30 stainless v banded housing. Main purpose was instant spool and towing abilities. The truck on stock fuel makes 700 hp and sounds like no other. It’s a really fun truck to drive. I will try and post a sound clip of it driving off. Total boost is 59 psi. I have plenty of high hp trucks but this one is so pleasant to drive.
Yea I knew you were aware. I quoted the wrong post.I do understand they make those I was just saying what I did and how I like the setup done when one has the money to do it.
No way is 65/85 going to be worth a chit on stock fuel.... Compared to a stocker/75, I have ran several versions on stock fuel and hands down the 75 over stock was the most versatile and fun. Now built eng is another story...
My daily driver has a 65mm vgt in the valley and a 485/96/ T-6 1.10 as the atmosphere, I used the 1.10 as I already had it laying around. I'd use the newer 1.15 if I didn't, its more cost effective and a REALLY nice housing for the same purpose.
It made 1132hp at the tire on my chassis dyno before I quit turning it up. It drives like stock and tows absolutely awesome!
Assuming the cam & head & compression ratio differences are not extreme, most people with 'built' engines could put their air and fuel setup on a stock long block and they wouldn't know the difference. And vise versa.Say what you want... The op wants a great towing setup at 600hp and from what I can tell he’s on stock fuel/bottom end. My 82/87 with a 1.1 housing is not better than the 75 I replaced it with. It has more power potential (that was never being debated)... Comparing built engines to stock engines is laughable:rofl:
